Page 70 of 132 FirstFirst ... 20 60 66 67 68 69 70 71 72 73 74 80 120 ... LastLast
Results 1,036 to 1,050 of 1980
Thread: Sloth
  1. #1036
    ok please learn me how to wire relay's
    F*ck off cj.
  2. #1037
    look at the top of the relay to get the pin #'s
    30 should be what you are controlling, could be source or out depending on what you are doing. 85 and 86 are the coil that controls the relay, one should be + and the other -. 87 is the normally open side, usually you use this. 87a is the normally closed side, its the middle prong. not all relays have this
  3. #1038
    Planning a switch panel to replace the old center section. I'll make it out of some thin stainless or aluminum. Safety switches for the Fuel, Ignition and winch. Master on off switch and switches with the rubber boots on them and open indicator lights on all of them. I'm going to really get into my wiring soon. It is getting to the point that it's a fire hazard. So i'll have relays going to all of the single switches.
    Rewired the check engine light after the near fire at k2. Put a new light in there that hasn't been crushed by a rotor so it works.
    Went through all of the under the dash wiring and made it alot safer. Also a new alt belt.
    put the tester on the bronco at work today. 925 cca out of the 880 cca battery, 14.2v at idle without load, 14.1v at idle with all of my lights and my heater on. 42mv ripple, 730ms starter time.
    F*ck off cj.
  4. #1039
    Since I am posting in a public section, I heard about some kids back in the day that used to make such a switch out of the back of a stop sign or street sign, it is all shiney on the back.
  5. #1040
    Oct 2002
    Poth, Tx
    If those are 55w cheap lights, a pair makes 110w so less than 10 amps. Not sure why they supply a 30 amp fuse and 18ga wire. I use a 20 amp fuse on them, and 14 ga wire. The setup they supply those with does burn before the fuse, actually burns even if nothing goes wrong.
  6. #1041
    Also planning a bumper
    Going to get it milled out of solid titanium. That's why I made a cad drawing.
    F*ck off cj.
  7. #1042
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    Titanium... Pshhh. Unobtanium is where it's at
  8. #1043
    Hitch pin hole behind or in front of bumper?
  9. #1044
    behind. With the shackles there, i won't need to use that hitch much, unless you break your dodge at alto and I have to tow it home.
    F*ck off cj.
  10. #1045
    Rawr TexTJ209's Avatar
    Waco, Tx
    Please tell me that second part is a joke. I'm not current on titanium prices, but I'm fairly sure that would cost more than the truck.
    '81 CJ7 Laredo, 258/T176/D300
  11. #1046
    its a joke
    F*ck off cj.
  12. #1047
    Waco, Tx
    Sometimes I wonder with you guys, so figured I'd check.
  13. #1048
    finally broke down and bought one of these. fawking $40
    Took this toolbox I bought from blankenship and decided it needed a highlift mount.
    I put the bolts through the part which is 3/16
    F*ck off cj.
  14. #1049
    The box turned out well Tommy!
  15. #1050
    Returned this for gas money
    I don't want my stupid rock lights anymore. I want these.
    http://www.visionxwholesale.com/prod...Light-Kit.html
    F*ck off cj.
