Page 6 of 6 FirstFirst ... 2 3 4 5 6
Results 76 to 88 of 88
Thread: 1980 Toyota ***ux
  1. #76
    Probably to make it easier to put the shaft in. I would think it serves as a baffle to keep most of the oil in the third member so the seal has less of a chance to leak. The weep hole in the bottom is probably so the oil that does get past it doesn't just sit there.
    F*ck off cj.
  2. #77
    Rawr TexTJ209's Avatar
    Waco, Tx
    How the hell is Eric? Haven't heard from his smelly hippy ass in forever.
    '81 CJ7 Laredo, 258/T176/D300
  3. #78
    Oct 2002
    Poth, Tx
    He's back in Houston now, finally moved in with his wife.
  4. #79
    what hippyis in houston awesome time to get a beer....
  5. #80
    F'ing toyota gayness!!! Go to put the front axle back together and I notice the axle shaft is way off to one side. The damn axle housing is bent!!!Name:  IMG00820-20120901-2112.jpg
  6. #81
    Why is your jackstand grabber green?
  7. #82
    with your mom
    Lay some bead one the opposite side it should straighten
  8. #83
    It's ****ed. Sell it!!!
    F*ck off cj.
  9. #84
    Grabber green is so awesome it gets on everything it touches, just like the HIV
  10. #85
    Boy howdy, and the HIV is sure hard to wash off....
  11. #86
    So thanks to the Hippy, I know have a new to me axle housing. Here is a question for you guys, using the interweb it looks like these housings bend pretty frequently, my axle might have actually been bent from when the axle truss was welded on. When they bend while driving it is usually from doing sweet ass jumps, and it usually bends out by the knuckle where most truss's do not support. So here are the questions:
    1) Should I cut the "Toyota" truss I have off and carefully weld it to the new housing. This obviously strengthens the housing, but it does nothing to prevent bending out by the knuckle. Also if I do not weld it properly I run the risk of bending this housing???
    2) Should I put some trusses/re-inforcement at the knuckle. Marlin Crawler sells this kit,
    http://www.marlincrawler.com/axle/fr...kle-gusset-kit
    but I think I could cut a simple brace out of steel and weld it on.
    3) Or should I just say, f'it and put it in as is?
  12. #87
    Chubby Bunny davido's Avatar
    Mar 2002
    College Station, TX
    My vote, you're probably fine, but if you're concerned about it, do all of it now and be done with it. Not sure if Scott ever had a brace. If not, you probably don't need one.
  13. #88
    Registered User jasonjuch's Avatar
    Sep 2008
    I use lowrangeoffroad.com, i feel their prices are cheaper than marlin or trail gear. And I have the knuckle gusset kit and diff cover because I hear they're worth it. I never did the upper axle gusset because I have that factory lower one.
