JK hoods are higher no need for High line. most people just cut the existing fenders on JKs also and don't replace. 4 door is the way to go. If you really want a 2 door I have a friend here with a really nice 2 door he is going to trade for a 4 door. The 4 door seats 5 while the 2 door only does 4. You get a lot of storage space in the back also. The wheelbase is 116 which is a little on the longer side but it makes the pucker factor go way down with big inclines. You will know the first day you own a JK that the hood latches are crap and the hood looks like it is going to rip off. Drake Off-Road Hood Latches fix the problem and are a must. You can run 37" tires with no lift on a JK with only cutting the fenders FYI. The build on mine isn't far at all yet. I am collecting parts right now but will be running 42s with less than 4" lift.
