View Poll Results: Which engine option
Voters
19. You may not vote on this poll
  • Ecoboost
    3 15.79%
  • 5.0
    8 42.11%
  • All new trucks suck
    5 26.32%
  • I am a whore
    3 15.79%
Page 6 of 8 FirstFirst ... 2 3 4 5 6 7 8 LastLast
Results 76 to 90 of 114
Thread: Ecoboost vs 5.0
  1. #76
    DFW
    People will over analyze everything, just go buy what you want. If you want an ecoboost go buy it. Who gives a **** if a turbo goes out if it is under warranty, you will give it to ford and drive your dodge for a while. Just go buy what you want man, no one here is going to convince you otherwise, nor should they.
  2. #77
    Dodge 1/2 ton diesel. Just to add to the equation and you said you wanted a diesel anyway
  3. #78
    On my '06 duramax the mileage on the computer has always been within 0.1 mpg of what I hand calculate. It is the first vehicle I have ever scene that is accurate.
  4. #79
    May 2003
    Htown
    My dodge was correct to the nearest 1000 mpg. It was annoying because the mpg-erometer cut off at 999,999,999.99 mpg and I hand calculated (with my abacus) way better mpg than that.
    So you loose, I win!
  5. #80
    Quote Originally Posted by colman View Post
    It's been talked about and I'm looking but it's hard to find one equipped like I like for a reasonable price.
    My dad's '12 mpg readout is always spot on and I have a very hard time believing the readout would show less than actual.
    JB - I guess it's been hard to understand but my major concern is decent power/torque and not getting 10-13 mpg like I do with my current 6.2 v8.
  6. #81
    Only 5 more horsepower, torque is probably irrelevant since you will be towing with your dodge if you did have to tow
    Actually the torque makes a huge noticeable difference.
  7. #82
    Jan 2010
    Not unless you like winding your **** out to 5k rpm
  8. #83
    DFW
    Now you're just talking out your ass. Forced induction applications give torque low in the RPM range, turbo's are no exception. See the graph below for the Ecoboost.
  9. #84
    Jan 2010
    There's a lot of people talking out of their ass in this thread. Thanks for pointing it out.
  10. #85
    Jan 2010
    Here's the one you need. This is on a chassis dyno, not an engine dyno. Where is the ecoboost torque at 2k rpms where you will more likely be cruising at?
  11. #86
    DFW
    Oh please keep telling me all about chassis dyno's, enlighten me oh enlightened one. Point is you said winding it out to 5K rpms, The ecoboost has a fairly flat torque curve starting with 90% of it's torque between 2500-3000 rpm's (depending on the dyno). It is at least 50 ft lbs at the wheels above the 5.0 at 3K rpms, that is very acceptable when mashing the skinny pedal. There is no "winding it out" imo.
  12. #87
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    The ecoboost is lots of fun in the explorer sport. The truck just feels like a regular v8 to me. I don't recall ever driving the 5.0 so I can't speak to that.
  13. #88
    Mar 2009
    Quote Originally Posted by FJAggie07 View Post
    Don't be scared of Sticker on Dodge, it doesn't mean crap to them. I just bought a 14 Ram 2500 CC 4wd Cummins Laramie on saturday, sticker was $58K and I bought it for $48K. Probably could have got more off of it if I was financing but since I was trading in a vehicle with a higher trade in than the vehicle I was buying they didn't want to go any lower.
    Did you get screwed on your trade in? That seems like a smokin price.
  14. #89
    Jan 2010
    Who said anything about being enlightened? You posted a graph that means nothing in the real world. What the truck gets to the wheels is important. So I exaggerated a bit, so what. My point stands that at cruising rpm, the ecoboost doesn't make the torque that makes the difference between it and the 5.0 which means you're going to either give it more pedal than the 5.0 to do a small speed increase which means its either going to take longer to do the same thing or its going to downshift, and then upshift again once you let off. I dont know about you but i hate my truck downshifting on hills just to maintain speed.
  15. #90
    Then a chassis dyno means nothing either.
    From my experience ( several thousand miles in a 5.0 and a few test drives in a ecoboost )
    The 5.0 down shifts all the time which makes me hate the 6 speed transmission.
    The ecoboost can handle the passing lane without downshifting.
    And that is the main reason I was leaning towards ecoboost.
