Quote Originally Posted by FJAggie07 View Post
Oh please keep telling me all about chassis dyno's, enlighten me oh enlightened one. Point is you said winding it out to 5K rpms, The ecoboost has a fairly flat torque curve starting with 90% of it's torque between 2500-3000 rpm's (depending on the dyno). It is at least 50 ft lbs at the wheels above the 5.0 at 3K rpms, that is very acceptable when mashing the skinny pedal. There is no "winding it out" imo.
Who said anything about being enlightened? You posted a graph that means nothing in the real world. What the truck gets to the wheels is important. So I exaggerated a bit, so what. My point stands that at cruising rpm, the ecoboost doesn't make the torque that makes the difference between it and the 5.0 which means you're going to either give it more pedal than the 5.0 to do a small speed increase which means its either going to take longer to do the same thing or its going to downshift, and then upshift again once you let off. I dont know about you but i hate my truck downshifting on hills just to maintain speed.
