Here is the plan as i see it.
Make the b!tch run....fred cover your ears. Most likely this will involve carbing it. I got a free intake and 4 barrel from mike. Im going to rebuild the carb and clean up the intake. I cant work on it wear its stored, and I cant keep it in the driveway. If i carb it and make it run i can drive it to and from the storage place.
I can work on it my driveway without repercussion for a weekend. So when I want to work on it, i'll just drive it back over here.
As far as I know, everything but the motor is in working condition. Steering is all hooked up, and i think the brakes are good.
Here is what it needs to run:
carb rebuilt
intake cleaned up
new distributor
plugs/wires
i'll have to check on the fuel pump and stuff once i pull it out.
I'll have to get with karlisa and find a time in a couple of months when we can do it at don johnsons', i know he has alot of other projects though too.
We'll see how it goes.
Other plans:
either 205/203 doubler or 241/205 doubler
run the 44 for a while till i can afford a 60
cage
bumpers
new seats
fix heater
Originally Posted by
Graystroke
So you loose, I win!
- You may not post replies
- You may not edit your posts
Forum Rules
